Speakers - Can Someone Explain Henry's and Farad?
928 Collector
I have these, and here's an excellent manual. What do I need to run one of these in parallel with a 4-ohm midrange? Response on the midbass is 30 - 500Hz http://www.kicker.com/06/tech-suppor...icalManual.pdf
I installed it all, just need to know what sort of cap/coil I need.
The nearest table value to your application, assuming the new woofer is 4 ohms and the existing one in parallel with it is also 4 ohms is from page 11 "6db/octave bandpass" 2 ohm
80-400Hz 0.8mH 1000uF.
When you buy the 1000uF capacitor, make sure it is designed for use in a speaker system. Do NOT use an electrolytic capacitor, they are polarised and can overheat.
You must use a non-polarised capacitor.
