Late model (10 way) speaker grills for sale - + door sub-woofer spacers/grills
Electron Wrangler
All,
I have 2 pairs of black speaker grills in better than serviceable condition from my GTS. These are for the 6.5" round B-pillar (just the grills not incl. the spacer ring) and the upper quarter-panel grills (the horizontal speakers).
I also have a used (but not so much) pair of the stock GTS blaupunkt speakers to match the grills for the horizontal upper quarter-panel location.
Also some non-Porsche grilles & spacer rings - the same as I used for my passenger door subwoofer installation.
1) 6.5" grill pair black - (928.555.693.00) - 1 has no cracks, 1 has a single crack - repaired with JB weld (inside) visible but not obvious. Both grill covers have minor dents (visible only with difficulty). Grill diameter is 7 3/8"
These were installed with the repair on my GTS until last summer.
Pair $25 + shipping
2) Rear deck grill pair black - (928.555.691.00) - 1 has no cracks, the other has 1 full crack & 1 partial (slight) crack. The full crack is repaired with JB weld (inside) these cracks are slightly more obvious (than on 6.5") and are approx 120 degrees apart. However when installed on my GTS they were not very obvious.
Pair $20 + shipping
3) Original Blaupunkt rear upper quarter-panel midrange speakers approx 4.75" diameter (928.645.212.00) These were installed in my GTS until last summer - however they have not been connected since shortly after the car was new - when a different (8 speaker only) audio system was installed.
On one speaker the dome/dust cap is slightly dented and the foam is detached/split in 2 areas of approx 1/2" each - this one ideally needs new foam. The other looks to be in good condition.
See: http://www.partsexpress.com/resource...eplacement.cfm
Pair $25 + shipping
4) I also have 3 generic/non-Porsche 1" deep plastic heavy duty black spacer rings suitable for 5 1/4" - 6 1/2" speakers. This is the ring I used (with some filing down for fit ) for my door sub-woofer installation (lower front passenger door). The rings are 6 3/4" base diameter - and could possibly be used for B-pillar if shaped to fit (I considered doing this - but they are smaller than the round late model stock spacers).
All 3 for $15 + shipping (great for experimenting with adjusting to fit shaping...)
5) I also have 2 all metal 6 3/4" black grilles & screw down mounting plates that fit the top of these rings exactly (also as I used for my subwoofer). They can also be mounted on the spacer rings directly in compression mode (w/ rings reversed).
These are very similar in look to the 6.5" Porsche rings (though the grill mesh actually has raher larger hexagonal holes). Of course they will never crack and are much stronger...
Pair $20 + shipping
I'll happily combine shipping and will split these pairs/groups only if nobody wants them together...
Just cleaning out stuff I know I won't need again.
I will post pictures of these later... FCFS though.
Alan
Pair $25 + shipping
Pair $20 + shipping
Pair $25 + shipping
Pair $20 + shipping
Alan
Electron Wrangler
In the above set Pictures 1,4,6,8,11,14 & 15 show the cracked/damaged grills.
This (below) is how the installed subwoofer spacer ring & grill look.
Alan
Alan
