New Product: Ultimate Front Sway Bar Kit
Supercharged
Randy-
It's not the bar that rips the mount, it the force you put through the bar that rips the mounts. I would think that for most street drivers, you shouldn't have any issues - tracker... well that's a different story.
Developer
I think Andrew is right on this. Most street drivers will not crack the stock sway bar mount. But, the 928 swaybar mount is sorta tall and sorta week - high-performance driving and racing flex it - and by the time you put higher forces on it thru a stiffer bar, they tend to crack at the bottom.
The correction is easier before the sway bar mount cracks rather than after it cracks.
I wrote up the process several years ago and I have it among the instructions on our download page.
You may download the intructions (with pictures) for free on how to strengthen your sway bar mounts right here: http://www.928motorsports.com/install.html
Developer
The page for this is now up if you would like to order:
http://www.928motorsports.com/parts/...ontswaybar.php
The beefier sway bar transfers more torsional forces to the mounting points, regardless of driving style.
Bottom line - if you plan to upgrade the front sway bar, reinforcing the mounting points should be done first.
Carl, cool solution. I saw a similar bar on the front of some Supercup 951s last weekend.
DR recommends beefing the mounts for the stiffest setting of his bars, but I don't think it's necessary for the two lower settings which are both stiffer than stock.
Carl, I think the standard sway bars come in left and right hand drive versions to accomodate the differnet placement of the rack, I assume that with the straight bar, it will fit both LHD and RHD cars?
thanks
Jason
89 S4 RHD
thanks
Jason
89 S4 RHD
Developer
Yes, Jason - you are right. It certainly should fit RHD. I will not announce that it does until I've done it or one of my customers has, and as yet, I have not installed this new anti-roll bar on a RHD car. But I am sure you are right - there is no reason it would not fit.
Side benefit - because the end arms detach from the torsion bar - this will ship in a smaller box than other sway bars. Saves $$
Developer
Here is the spring rates of the bars for those that asked. We offer our front bar in 3 different spring rates as shown, plus each bar also has 3 different drop link mounting positions so you can really adjust the bar well to your individual car/weight:
Porsche 928 Front Sway Bar
Size / Wall Thickness / Rate*
28mm OD OEM hollow bar / .176” / 210
1.25” OD 928M GT3 hollow bar / .120” / 313
1.25” OD 928M GT2 hollow bar / .188” / 414
1.25” OD 928M GT1 hollow bar / .250” / 475
* Spring rate measured in pounds @ 5 degrees of twist, with a 10” lever arm Measured on a 38.5” center section
Our listing:
Our listing:
