928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine Rebuild Question
Old Jun 7, 2002 | 01:46 PM
bergstsm's Avatar
bergstsm
Question Engine Rebuild Question
I am giving serious thought to completely stripping my 86 to the ground and rebuilding, due to some laziness on the part of the PO. In that process, I was starting to think about some engine mods. I would prefer not to turbocharge or supercharge, but I would like a bit more power and/or displacement. Are there some routes that people have taken and would be willing to share?
At this time it is just a dream, but next spring is when I may get started. Just trolling for ideas!
Thanks,
Shawn
*Mine is an 86 A/T
Old Jun 7, 2002 | 02:17 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Lightbulb
Well, I am taking a '85 Euro intake and heads and mating them with my '86 engine. Some think this is the easiest way to add 50-60hp.
Old Jun 7, 2002 | 06:01 PM
Dozman's Avatar
Dozman
Post
Would like some advice on the Same as Berg. I will be coughing up the money to do the engine work THIS winter. My question is, what are my options, and cost of thoose options. I would like to get enough horsepower to get my Shark ahead of a the camaro's, a few vettes, and more than a fair share of foriegn cars (I won't go there. Rice Burners ).
Now if this means stroking the engine, super charging, turbo's, new heads, head work Fine. I am looking for serious on the spot guidance. Just need some of the gurus to help with the knowledge. I know budget budget budget. I am looking at dropping maybe $4-6,000 in the engine during the winter. Maybe more during the spring, if needed. Not looking to make the fastest thing in the world. But quick enough to smile.
I have a spare '85 engine to work with from the donor shark I have. I think this will make it easier to work with. So, I can work on the engine and not worry about pulling mine till the new power is ready to be installed.
Secondly, Since I am not looking to go 160 MPH, is it s good idea to start thinking about different gears for the rear end? Not sure to look at the engine build, then the rear or reverse. I will be driving on the streets and highways.
John D.
'85 928 Auto, Black
Old Jun 7, 2002 | 07:20 PM
Rob M Budd's Avatar
Rob M Budd
Post
Last year I had the same thoughts about my 80. More power, etc. I checked out the cost of rebuilding with some modifications to add some horses. I found it to be somewhat expensive, so I opted for converting to a SBC 5.7 LT1.
The conversion job itself was a lot of fun and very rewarding.
Just something else to consider.
Bob
[quote]Originally posted by bergstsm:
<strong>I am giving serious thought to completely stripping my 86 to the ground and rebuilding, due to some laziness on the part of the PO. In that process, I was starting to think about some engine mods. I would prefer not to turbocharge or supercharge, but I would like a bit more power and/or displacement. Are there some routes that people have taken and would be willing to share?
Thanks,
Shawn
*Mine is an 86 A/T</strong><hr></blockquote>
Old Jun 7, 2002 | 07:53 PM
Donald's Avatar
Donald
Post
robm-
Did you purchase a converter kit for the sbc? Which bits went away & how do the flywheel/FI connect (or is that a carb engine)?
TIA,
Donald
Old Jun 7, 2002 | 08:05 PM
lobis's Avatar
lobis
Post
There is a place near where I live that will put two turbos and an intercooler on my car for about 5k. They do lots of turbo mustangs, and camaros. Also they know how to install and tune TECIII engine managment systems. I am going to do that and 944heads, and euro throttle body and intake. I am looking to spend around 10k with everything i want to this fall. 84 928.
Old Jun 7, 2002 | 08:12 PM
Mike Schmidt's Avatar
Mike Schmidt
Post
Old Jun 7, 2002 | 08:14 PM
Mike Schmidt
Post
Depending on what your goal is, and how much you want to spend, that it's really hard to give specific advice. Here's a link to some information on a guy with an '85 automatic.
<a href="http://www.marcus3.com/porsche_page/porsche_page.html" target="_blank">http://www.marcus3.com/porsche_page/porsche_page.html</a>
The last that I heard, it was making 480 hp and 520 ft/lbs of torque at the rear wheels, with a totally stock exhaust system. I guess it's getting headers and a free flowing dual 3" exhaust on it soon.
One piece of advice I can give is to do the gear change last, if at all. Depending on what you end up doing with the engine, even the gearing that you have now may give you much more wheelspin than you'd want.
Old Jun 7, 2002 | 10:40 PM
Rob M Budd's Avatar
Rob M Budd
Post
Yes. I used a conversion kit from Renegade Hybrids in Las Vegas. They've been extremely helpful too.
Their torque tube converter bolts right up to the SBC flywheel.
Its a 94 LT1 which is Fuel Injected and has a flashable chip. The Porsche system comes out intact and the GM system goes right in its place.
Bob
[quote]Originally posted by Donald:
<strong>robm-
TIA,
Donald</strong><hr></blockquote>
Old Jun 7, 2002 | 11:12 PM
Rob M Budd's Avatar
Rob M Budd
Post
Heres a link to some pictures. One day I hope to get around to adding some captions & explanations.
<a href="http://mywebpages.comcast.net/robmb/index.html" target="_blank">Porsche 928 LT1</a>
<strong>robm-
TIA,
Old Jun 8, 2002 | 01:09 AM
bergstsm's Avatar
bergstsm
Post
I apologize. I should have given a bit more to go on. Essentially, I want to retain a stock look. I have heard a few things regarding an upgrade to the 968 pistons, and some block work, without supercharging or turbocharging.
Has anybody gone this route with any results that I could look at, i.e dyno numbers? How about the DEVEK stroker kit, any testimonials? When I do this, I plan on replacing the lower block, as the PO's mechanic dropped it off the hoist and cracked one of the alternator mounts on the block, forcing me to JB weld the mess. Yes, my PPI mechanic missed that one, too! <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
Thanks,
Shawn
