Dry Sump or Accusump?
The scraper is a nice addition and will help, direct the output of the scraper away from the crank throw.....direct it into the pan!
You might want to reconsider the accusump as a means of keeping the engine alive under oil starvation situations caused by high g's.
Good luck,
Marc
I did give some thought to the oil staying on top of my baffle. It drains off of there at least as well as it does off of the rear higher portion of the pan, and it's not any closer to the rotating assembly than that part of the pan is. I found that polishing the rough casting surface of the rear portion of the pan seemed to help oil drain off of there better. A good portion of the area where the baffle is at is kind of shielded from the rotating assembly by the oil pump pickup tube and bracket too.
The breather modification and scrapers should also help to reduce the oil cloud, and also to help oil drain back from the passenger side cylinder head. The blowby gasses are being drawn out from the crankcase only, and not from the valve cover. That will prevent any blowby gasses going up through the drain holes at the same time that the oil is trying to go down those same holes. The scrapers are also positioned so that they shield the oil drain openings from that head from any oil that might be thrown at and into them by the rotating assembly.
My thinking is that the dry sump would be the best way to go. I do think that the Accusump helps too though. Anything that will help keep a little more oil where it's supposed to be. I'm thinking the modifications I did should do that to at least some extent.
The truth is that I probably really don't need anything. My car is an automatic that basicly spends most it's life in "D", and I don't track the car. The stuff I did was primarily to try to improve things a little bit while I was in there, and to maybe pick up a little power from the scrapers and breather modification. I'll have to wait and see if they actually did that when I get the car back on the dyno.
Anyway, he explained at length about the multitude of additives they use to control foaming. He says it's the single biggest problem they face racing, especially the banked ovals. Almost every track gets a different formula with the idea of controlling foam and thermal breakdown. When they get it right it makes all the difference.
Mike LaBranche
84S, black/black, AT
83 EuroS, weinrot, 5spd
