ABS Testing
available in great slabs.
I found the following generic data on a Rover 800 site and thought it may be usefull.
It mainly relates to Sensor testing but I have found that the first place to look is Relay XVII (MY87). If you remove the relay and jump pins 30+87 the ABS warning light should go out...if it still stays on it's likely that the problem is not the relay but elsewhere...most likely the wheel sensors.
ABS Testing link is:
<a href="http://www.davep1.freeserve.co.uk/rover/tech/absoview.htm#The%20ABS%20System%20and%20the%20ABS%20Warning%20Light" target="_blank">http://www.davep1.freeserve.co.uk/rover/tech/absoview.htm#The%20ABS%20System%20and%20the%20ABS%20Warning%20Light</a>
(There is a section on fault codes which I would disregard for our cars)
Hope its of some use.
Jim
