928 Forum 1978-1995
Sponsored by: 928 Specialists
WTB PorKen Tensioner Bracket
Old Sep 26, 2007 | 09:47 AM
Vlocity's Avatar
Vlocity
Default WTB PorKen Tensioner Bracket
Hi All:
I pulled the front of my engine down last night after an intermittent timing belt light. The belt is still within the tension spec and everythng actually looks good....except that the tensioner has leaked most of the oil out and I am getting tired of rebuilding it.
I know that Ken plans to make a new run of tensioner brackets soon, but I'm looking for one to purchase now so that I can get my car back together and make the next track event that I have scheduled for October 11, 2007.
If someone has a bracket available and just hasn't gotten to their project yet, I'd like to purchase your bracket directly or pay for shipping charges and your inconvenience and have Ken send you a replacement out of the next batch. Whatever works for you.
Please PM me if you can help. I need a 1985 bracket without air pump.
Thanks all.
Ken B.
Old Sep 26, 2007 | 11:09 AM
the flyin' scotsman's Avatar
the flyin' scotsman
Sorry Ken............I'm using mine.
As well as the bracket you need the pulley, lever and tensioner as well as hardware. You should gather all the parts with a new belt. The waterpump is also a consideration depending on when last changed and/or the desire to do the work again should it fail in the near future.
Old Sep 26, 2007 | 11:28 AM
Vlocity's Avatar
Vlocity
I have most everything else sourced. Just have to pull the trigger if I can get the stars to align.
Thanks,
Ken
Old Sep 26, 2007 | 11:57 AM
Tom. M's Avatar
Tom. M
Deleted
25 Year Member
Check to make sure you have that little circlip on the back of the big roller. My tension light was doing that too....and it was in tension...but the tracking was slightly off on the passenger cam.. Ended up doing a new crank gear and adding the circlip..that keeps that roller in the proper alignment. Of course..after all that..I too will switch to the Porkensioner as soon as he starts another run...
Good Luck
Tom
89GT
82 Trackster
Old Sep 26, 2007 | 06:10 PM
90 S-4's Avatar
90 S-4
Ken,
FWIW -- I have one of the S4 brackets that PorKen made but later said "wait" the spacing is off or ?
he called them the paper weight brackets and replaced it with the final version. Anyway your welcome
to take mine N/C and modify it to fit your mtr, then when his next batch comes out you could swap it out.
It might help to get you back on the road sooner . You could check with Porken to see if it's do-able ?
Old Sep 26, 2007 | 11:16 PM
Vlocity's Avatar
Vlocity
Thanks to all......but it I just ordered a rebuilt tensioner from 928 International and it will be here in time to put the car back together Saturday morning. Looks like I will table this for a few thousand miles.....or more hopefully.
Regards,
Ken
