How Do I Run A Hose From the Engine to Cabin????
I need to run the boost gauge line from the engine to the cabin. Where can I find or make a point of penetration through the fire wall? All suggestions or BTDT appreciated.
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Andy K
Andy K
This is where the vac line for the HVAC comes through the firewall. It's real high up near gas pedal. You have to pull the insulation down to see it. Use one of the spare holes and if all holes are taken, make a real small hole for your line. You want the rubbber to close around your line. Use simple green or any other soapy cleaner to help the line slide through the hole.
Greg
What Greg said, plus:
Use a round pokey thing, like a nail or awl, to penetrate this thing, either one of the blanks, to get a resealing hole. Do NOT use a blade.
