GTS Oil Pan Baffle
GTS Oil Pan Baffle
I've got one here so I may as well put it in. (Just changin Rod bearings/ pan gasket/ MMs/ Rack re Seal etc.)
Anyone got a picture of one installed ? It looks fairly obvious where it fits but some reassurance would be nice. And is there a spring involved ???? THe bag with the bolts in has a spring about 2" long and about 3/8" dia and I can't imagine why you'ld need a spring.
TIA
TIA
Cottage Industry Sponsor
When I had my oil pan gasket done in Santa Monica before I drove the car home for the first time, I asked for that baffle to be installed. But I have no way of verifying that it was actually done... I hope I won't have a "surprise" when some day the oil pan comes off again...
Thread finsihed. Thanks Stan - looks just like mine does except mine is cleaner. Another check in the morning for Oil pan shavings and the pan goes back in. So do I send the spring back to Jeannie ? thats where it came from about 4 years ago. I suppose the big question is what is the spring for? who ordered something from D and J about 4 years ago that should have had a spring that they didn't recieve but I did.
Anybody want a spring ?
Cheers
Cheers
I don't think that the GTS baffle is worth installing. When I added it there was no improvement in oil ejection. I'm reminded as well of someone (Don H?) who had it come loose.
FWIW- Here's a clean one installed over a OB-style screen cover.
I'n very happy with the Ishihara-Johnson windage setup. That is lots more $$. Kevin Johnson at I-J did send me an experimental sump cover that was really sweet as an early attempt. It was very much better than the GTS cover and there's a pic on the following page.
Here's some saga:
http://home.earthlink.net/~bigdadglen/carpics/id10.html
Here's some saga:
