Opening this thread you agree to never say the 928 is difficult to work on...EVER!!
Enzo, that's a 4.9L engine you got in there. Since you do not have the Mustang's "5.0" badges on the fenders of the Cobreplicar to confuse the issue, you can refer to it by its correct displacement.
My '79 Volvo was the engine I've ever worked on. There was so much room in the engine bay, you could pretty much sit on sit right in there whenever you needed to! The windshield wiper motor & mechanism was the worst to work on, though - they were as far away from human access as they could be. Fixing the wipers on my sister's '80 240 took a day to get in, a day to replace the parts, and a half day to put it all back together.
Administrator - "Tyson"
Rennlist Site Sponsor
Jag XJS - I have never owned a car that had so many fasteners that you could see, and touch, and could not get a wrench on...
(Including our '59 Mini with an 1100 engine.)
There was even a direct and specific warning in the factory shop manual that said that the XJS was hard to work on!
Chronic Tool Dropper
Reality is that the thermostat is perhaps the most reliable component in the car's cooling systey, yet it's the first thing that gets blamed when a car runs hot. It's usually also one of the easiest things to change. Usually. The 928 thermostat change is hampered slightly by the fuel ine that blocks access to one of the housing bolts. Loosen that, a little puddle of gas that goes away quickly, and out comes the thermostat. Then pry out that inner o-ring used for the bypass seal at the back of the housing. The more the o-ring is dried out the more it needs to be changed and the harder it is to get out. Reassemble, with the little dogbone vent at the top. Refill, burp, refill, burp, start and warm up, burp, get the coolant flowing with some rapid hose squeezes to push any bubbles away from the thermostat in the crossover manifold. Top off the reservoir. Drive. Top off the reservoir. Drive. Watch the reservoir level for a few days of driving. Yep, the 928 thermostst is a breeze compared to others.
I think we need a poll on how many owners have changed the thermostat only, and found that their heating problems went away. No radiator service, no fan fixes, just found a bum thermostat. Anybody?
Captain Obvious
Super User
Super User
Quit your wining!
I didn’t have any problems rebuilding the engine on my 5.0 and the car is in EUROPE.
If I don’t have the right socket, I make one. Have a cheap set of sockets just for this. If the wall is too think or the length it too much, I grind it down. Use a torch to bend a cheap set of wrenches to fit every “custom” shape needed.
I’m not sure if you know this but the Right Stuff is one neck of a sealant, they use it on turbos too but wait until you have to remove it. You’ll learn a new meaning to the words PITA.
My Daughter's factory five I mounted a 928 front electric fan behind the radiator as a puller and that fixed the overheating issues ! That was the car with the seat belts......velcroed to the carpet !!!!! I was NOT amused by it. It has since gone down the road. Watch the door hinge pins they tend to fall out ...
My thermostat failed in the closed mode on the way to the Wichita 2000 OCIC. Gotta love Kansas, I couldn't believe all the people stopping to help.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
There was a truck building show on TV where they bought a used 4x4 to transform. When they peeled back the roll bar padding it revealed a PVC pipe rollbar!
A good padded PVC rollbar inside a street truck could easily be better than a steel one in a common accident. At least it will give some when your un-helmetted noggin crashes into it. Plus the PVC is kinder to the CG.
Looking at my door hinge, not sure what pin you are talking about. I do have the upgraded MKIII door hinge though.
Like my old (long sold) maintenance hog Ducati 888, the 928 is easy to work on, yes, but you sure seem to need to do a lot of it. Big difference between thr throwaway cars that are easy to manufacture but impossible to take apart here. You can tell that the manufacturing line wasn't as automated, either.
Attaching the harness to the car via velcro was never part of the kit. That is the #1 problem with kit cars, they are only as good as the person building them.
Captain Obvious
Super User
Super User
