Survey: Tyre pressure warning system.
Any system that has a set pressure as a minimum is flawed to begin with. The use of non-OEM tires, differing driving styles, road conditions, and other factors should be considered when determining 'proper' tire pressure. When a car manufacturer lists the tire pressure for its vehicle it should be as a guideline, not as a requirement.
Alhough Porsche says that my tires should be 36 PSI up front and 44 PSI in the rear, I have found (over 12 years of driving 928s) that 38 to 40 PSI all around works best for me. YMMV.
Electron Wrangler
My '94 GTS has RDK (just a few early '94's had it before I get a slew of mails on this) its fully functional but does give some grief.
Seems to consistently alarm @ 1-2 psi too low.
I also find that in the heat of summer it alarms more frequently - I think the temperature compensation is not really that good - as well as there does indeed seem to more rapid tire air leakage at extreme temperatures (Phoenix in summer = hot). Two seperate issues - one means the RDK should be especially useful in summer the other means its also a bigger pain then.
So a mixed bag - I think Porsche really screwed up in not creating a system that was externally calibrated w/ ability to reset thresholds for different tires. The whole calibration is manufactured into the phenomenally expensive RDK inserts in the wheel and cannot be reset.
However - how many other options for tire monitoring were there back when this was designed?
New systems from Beru (OEM) & Smartire (a few hundred $ retail)have some good features and 2 level calibration (Loss Warn/Emergency). Always wondered if it would be possible to interface one of these new systems into the Porsche dash display.. don't like extra display junk hanging around - never really gave it enough thought though.
For me its still worth it for peace of mind @ speed
Alan
Ed - check out smartire on tirerack.com sounds like what you mentioned
<a href="http://www.tirerack.com/accessories/smartire/smartire_all.jsp" target="_blank">Tirerack/SmarTire</a>
Alan
