next issue: engine stops on hard right turn
once in a while when I make a hard right turn the engine quits. after a few seconds, I can start it right up again.
it's not battery related since I don't lose electricity. in fact when the engine shuts off, all the warning lights go on, a/c and radio continue uninterrupted.
could it be low rpm or fuel starvation?
I've tried a couple hard turns tonight but in a lower gear and keeping the rpm's up. The problem is so intermittant that I can't say that keeping the rpm's up or lower gear is doing anything. It's maybe happened four times in the 8 months and 1800 miles I put on the care.
I've seen a thread about this, but it didn't seem that there was any definitive conclusion. (what fuse or rely should I swap; see my previous post)
any easily performed diagnostic test I can perform?
possibly related: after leaving it at the airport for 6 days. I tried to start, got electricity but it wouldn't turn over. like the starter wouldn't engage.
I waited a couple minutes and it started right up.
That can be a tough one to track down.. Had a friend with an old Volvo, when she turned on the left indicator the engine stalled. They never did figure it out.
At least she didn't drive for NASCAR
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
My car had an odd cut out problem over rough bumps....it wouldn't stall, it would just loose power briefly then return to normal......turned out to be a dying fuel pump! Its easy to check....pull the cover plate and check the resistance of the pump.....a good pump should be around 2 ohms or less.....mine would spike to 13-15 ohms and not run.....
