928 Forum 1978-1995
Sponsored by: 928 Specialists
This is what happens when...
Old Aug 25, 2007 | 08:14 PM
3000teeth's Avatar
3000teeth
Default This is what happens when...
...you mix-up your high-pressure and low-pressure power steering lines on the pump:
You start the car, everything sounds right, you look down and the alternator belt is moving just as it should. You smile.
Then, you turn the wheel an inch and the whole steering column goes into an epileptic seizure with the wheels moving back and forth like it's possessed. You scream WTF!, stop the car, start it again, open the PS reservoir and fluid spews out like your engine has a red-wine hangover.
It's a lot of fun, especially the part where you pull off the alternator again.
Old Aug 25, 2007 | 08:20 PM
SeanR's Avatar
SeanR
Man, I hope you didn't get any on the paint. That's going to be hard to clean up, just be sure not to run the car until it is. Stuff is pretty flammable.
Good luck.
Old Aug 25, 2007 | 11:10 PM
Jadz928's Avatar
Jadz928
This is what happens, Larry...
http://youtube.com/watch?v=IQUdJ6FdUQ0
Old Aug 27, 2007 | 11:09 PM
3000teeth's Avatar
3000teeth
lol --thanks, that took some of the sting out of it!
