Got pod back together, now lights stay on?
Just finished having my odometer fixed and changed all of my bulbs while in there. I got everything back together, but my drivers side parking lights stay on. My electric fan starts when I turn on the key. I don't remember it doing that before the pod work. Any help would be appreciated.
Hey Charles, welcome.
That's a new one. This is the exterior parking lights, right? Both front and back?
Normal operation is for the exterior park lights to illuminate when the turn signal stalk is turned on, with the key in the off position.
Perhaps you upset the turn signal assembly when you removed it to gain access to the pod?
The aux. electric fan should run when you have the climate control set to AC or Defrost. Doubtful it's related to the pod work.
Maybe a few more clues would help.
I narrowed it down to the light switch on the pod. When I wiggle the wires on the back of the switch the exterior drivers side park lights go off and on. Sometimes it gives me a "Tail Lamp" warning and when I turn the lights on and off a few times the warning goes off. When I look at the tail lamps the passenger side light is off but the bulb is good. My interior lights don't work now also. I hope I didn't screw up anything.
