88 with electonic code faults?
As tested with KTS 300/PST 2- we have two issues that, MAYBE, OTHERS have had to deal with too?
engine performs lethargically-code is "closed loop system limit"
Second involves the diff wheel locking light on dash-tester showed L/F wheel sensor fault-although when testing it, it showed that it was signaling, changed it with no change in results-ANY SUGGESTIONS ON THESE TWO "FAILURES' APPRECIATED-go you sharksters-thanks Mark
