Steering Rack Universal Joint
On the Bandwagon
Got everything back together, with dimple located in rack and steering wheel straight.
However, I cannot get the universal joint back onto the steering column - I just can't get the angles lined up.
I'm tired, and will try again in the morning, but in the meantime - any suggestions???
Team Owner
you may have to drop the rack a bit to feed the coupler back onto the splined shaft its not hard but a bit of a pain, you may also have to disconnect the feed line to the rack as well so you dont bend it when dropping the rack it only has to come down about 2 inches or less on the driver side
On the Bandwagon
