loose wires wiper area
I found three disconnected wires bundled together under the plastic cover along the front of engine bay (wiper and blower area). After looking for possible connections I found the wires of the engine bay light and right washer nozzle (from divers view) cut off.
Small intermezzo: it never seizes to amaze me that some po's show no love what so ever for these beautiful cars and simply cut stuff off if it's in the way... I should start a thread on what po's did to get rid of my frustration..
Can anyone confirm that the wires from the engine bay light and washer nozzle come together in a three pin socket?
Aryan
Aryan
Electron Wrangler
I don't think there was a plug/socket there - the wires do indeed go as you noted, I think probably the hood was taken off and the wires chopped then. You can add a connector there to fix this - and its a better solution in case the hood ever needs to come off again.
Alan
Alan
Team Owner
there are a few connectors for the hood both for the heated nozzles and the hood light should be 3 connectors the connectors are usually routed under the black cowl cover and then into the wire loom a little bit of digging you will find the connectors and then figure out what needs to happen
