Connecting rod side clearance and width
Probably a question only few may know, what is the rod side bearing clearance and how wide exactly are the rods on the big end?
- Rod lower end width 928 27.0mm
- Rod lower end width 924S/944/S/S2/951/968 29.0mm
- Rod lower end diameter 55.0mm
- Piston wrist pin diameter 24mm
- Rod upper end width 26.5mm
- Piston opening width for the rod upper end 30,5mm +/- something depending on pistons
The big end width is absolutly not 21.7, what source said that? Erkka is a reliable source of data, you can trust him. BTW, the maximum width of the crankpin is 54.13mm. What do you have planned?
Thank Mike. Everyone can make mistakes but I think this time 27mm is correct. 21.7424mm would be very strange measurement for German company to use.
I saw on a pauter rod website the 928 porsche b.e. width listed as .856, lol. It seemed very small, I should have just thrown up the link instead of openly doubted you. My appologies ![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
http://www.importperformanceparts.ne...sche-rods.html
how much do standard rods weigh in the early 32 valve engine? i was looking at these
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ayphotohosting
