headlight...no beam...no motor
Just swapped fuse/relay panel from my wrecked car over to my project car. Took all my relays and fuses with it. I trust little in the project car.
It has improved a few things...BUT...my headlights are completely INOPERATIVE...no motor...no light. Replaced the relay for the motor....still no motor. Replaced the relay for the fuse....still no light...hi beam or low. No go when I manually raise the lights either.
Wondering if I disturbed something in a wiring harness...as the lights did function before. Which one of our lettered friends might be carrying that power? Any other ideas? I am in the dark.
Chris Magid
1984 928s x2
Chris Magid
1984 928s x2
It may not apply but my lights died, at night, at a gas station, halfway between Kansas City and Des Moine. I shut them off while still "up" and when I started the car, no lights. For some reason, the switch that tells the motor that the lights are both up or both down wasn't tripped.
I loweed them by hand and gave each one a final push until I hard a "clunk". Then they worked fine. - Ruf
