928 Forum 1978-1995
Sponsored by: 928 Specialists
Dexron ATF
Old May 21, 2002 | 09:17 PM
goodspeed's Avatar
goodspeed
Post Dexron ATF
What is the difference between
Dexron II AND Dexron III?
<img src="graemlins/yltype.gif" border="0" alt="[typing]" />
Old May 22, 2002 | 05:53 AM
Dave H.'s Avatar
Dave H.
From: Seattle - it's not Hell, but you can see it from here!
Exclamation
not enough to worry about apparently. i've been adding III to the PS since i couldn't find II anywhere. even if it says "Mercon" on the bottle, it's ok...
dave
88 S4
Old May 22, 2002 | 08:55 AM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Post
The fine print on the Dexron-III/Mercon bottle states that it supersedes/replaces Dexron and Dexron-II. Use it with complete comfort!
Old May 22, 2002 | 09:04 AM
Greg86andahalf's Avatar
Greg86andahalf
Post
From the Chevron Lubricants website:
DEXRON® -III
This is a specification for General Motors vehicles, but many foreign manufactures specify a DEXRON approved ATF as well. DEXRON-III can be used in transmissions that call for DEXRON-IIE or DEXRON-II.
MERCON®
Most Ford vehicles manufactured between 1980 and 1999 specify a MERCON ATF. ATFs that meet DEXRON-III requirements usually meet the MERCON requirements as well.
MERCON® V
Beginning in 1997, Ford began building transmissions for some of their large cars, trucks and vans that require a MERCON® V fluid. As of 1999, all Ford automatic transmissions require a MERCON® V fluid.
Type F
Type F is specifically designed for all pre-1977 Ford vehicles and some makes between 1977 and 1981. Effective March 1997, Ford discontinued administration of approvals for Type F fluids. However, there are still many vehicles on the road that use Type F. Type F and MERCON fluids are not interchangeable.
ATF+3® /ATF+4®
DaimlerChrysler has had their own ATF specifications for many years, but as of 1997, Chrysler owners' manuals no longer list DEXRON as an acceptable replacement. ATF+3 is a readily available mineral oil-based ATF that is suitable in any application calling for ATF PLUS® , ATF+2® , or a Type 7176® fluid. Vehicles manufactured after 1999 require ATF+4® , a synthetic-based ATF only available through DaimlerChrysler.
Greg
Old May 22, 2002 | 10:40 PM
goodspeed's Avatar
goodspeed
Talking
Thanks Guys,
The car runs GREAT!
Now I can GET ON IT, and feel good.
Thanks vary much.
BRRRRRRRRRRMMMMMM
Greg <img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
