928 Forum 1978-1995
Sponsored by: 928 Specialists
86 928 engine stumper
Old Sep 25, 2002 | 02:04 PM
Mark Stahl's Avatar
Mark Stahl
Post 86 928 engine stumper
what might cause a cylinder to show OK on compression and leakdown and yet foul the plug with oil?
thanks.
Old Sep 25, 2002 | 02:30 PM
Fastest928's Avatar
Fastest928
Post
oil past the valve guide
marc
DEVEK
Old Sep 25, 2002 | 04:13 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Post
Oil consumption in a cylinder does not have the relationship to compression that you might think.
Compression is determined by:
-Quality of sealing by the compression rings on the piston, which is affected by bore quality and the condition of the rings.
-Quality of sealing by the valves and seats.
-Quality of sealing by the block and head, which is not a factor without physical damage, such as a blown gasket.
Oil consumption thru the cylinder is determined by:
-Oil control by the oil ring on the piston, which is affected by bore quality, ring condition, and crank bearing condition. If the bearings are worn, more oil will be thrown on the cylinder walls, and the oil ring may be overwhelmed.
-Oil control at the valve guides, which is determined mainly by valve guide wear and oil seal condition.
As Marc says, oil loss thru the intake guide will end up in the cylinder. There can also be significant oil loss thru the exhaust guide, but that normally goes out the tailpipe and plugs the cat. The extra oil in the cylinder will actually help the compression, not lower it.
Oil going by the rings can make even more improvement in compression. The added oil improves the sealing on the compression rings.
I rebuilt a Corvair engine that 25k later went from no oil consumption to a quart every 75 miles. I checked the compression - new spec was 140 psi, and I had 200 to 225 psi. The oil rings were faulty, and were flooding the compression rings with oil. Bores and compression rings were perfect.
Old Sep 25, 2002 | 05:23 PM
Mark Stahl's Avatar
Mark Stahl
Post
very educational; thanks!
i had assumed that if the piston couldn't control oil getting past it that it would not produce compression.
so let's say oil is getting past the valve guide. What is involved in repair? pull the head and...?
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
