aiming washer nozzles
Captain Obvious
Super User
Super User
yup, adjust, then go for a drive. If needed, adjust some more!
I've used a simple needle to adjust washers nozzles in the past. Haven't had a need to do it on the 928 but it looks that a needle work too.
Craic Head
I was used to the ones that you can bend to adjust too. With these, each jet can be moved within the housing without moving the rest.
I used a paperclip, a very small one. You just stick it in the nozzle to pivot each jet, test, adjust, repeat.
