928 Forum 1978-1995
Sponsored by: 928 Specialists
Koni shock setting
Old Apr 12, 2003 | 10:17 PM
Paul D's Avatar
Paul D
Post Koni shock setting
Anybody using the internally adjustable Koni/Eibach setup have recommendations on the setting of the Koni's? Right now I have all 4 set to full soft and the rebound seems a little too soft. I'm going to set them stiffer but don't know if I should go full stiff on all 4. Thanks in advance!
Old Apr 12, 2003 | 10:43 PM
Ed Ruiz's Avatar
Ed Ruiz
Post
I've got mine set to 80% stiff up front and 66% stiff in the rear. These settings worked well for autocross events, DE, and normal street driving. YMMV.
Old Apr 12, 2003 | 10:53 PM
Paul D's Avatar
Paul D
Post
Thanks Ed! That's the input I'm looking for. I only want to do this procedure one more time so I'd like to get it right.
Old Apr 12, 2003 | 11:01 PM
Ed Ruiz's Avatar
Ed Ruiz
Post
If you're not going to drive the car aggressively, (as one would in autocross or DE events) then set the shocks about mid-way, but for safety set the front shocks a bit stiffer than the rears. YMMV.
Old Apr 12, 2003 | 11:11 PM
Paul D's Avatar
Paul D
Post
Stiffer settings up front would tend to make the front end 'push' which is safer than oversteer? Is that the science behind your recommendation? I do run a couple DE's during the year.
Old Apr 13, 2003 | 12:29 AM
Ed Ruiz's Avatar
Ed Ruiz
Post
There are several factors that can affect a car's balance, and whether it predominantly has understeer or oversteer. Shock setting are only one of them, and usually not as important as alignment, tire size and tire pressure, spring rates, sway-bar settings, etc. Nonetheless, setting the rear shocks a bit softer than the fronts will help reduce the chance of inducing oversteer. YMMV.
