928 Forum 1978-1995
Sponsored by: 928 Specialists
Wire Question 86S
Old Aug 2, 2007 | 03:04 AM
jcb928's Avatar
jcb928
Default Wire Question 86S
Would the bare wires to the Temp 2 screw up the sensor at all? Are the wires in the second pic connected the right way? (I know the p.o did not route them the right way)
File Type: jpg
File Type: jpg
Old Aug 2, 2007 | 09:43 AM
Adam Geist's Avatar
Adam Geist
I don't think the bare wires touching each other would damage the temp II sensor BUT it could send erroneous temperature data to the EZK and LH brains.
One terminal on the sensor is for EZK (ignition) and the other for LH (fuel). Proper test of the sensor is to check for resistance of the individual terminals to ground and not between each other.
Adam
Old Aug 2, 2007 | 12:16 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
If the wires are the same colour then it doesn’t matter how they are hooked up to the sensor as long as its the correct sensor.
As for the first pic, are the end of the wires actually hooked up to the connector or are they pulled out?
