Stroker Crank Question.
One of our customers , our crank just dynoed at 400 Hp rear wheel that is with cams and head work 6.5 liters . 16 valve heads
Jim,
How many RPM for that Power level? You guys must be turning 7000 rpm to make that much power...
You using stock rods? At that engine speed, inertial loads must be pretty high. Nonetheless, the numbers are very impressive.
It all depends on who builds your engine and what components they use. Bob DeVore (The DEV in DEVEK) managed over 700 crank hp in a 16 V config with an early 6 cwt edition of a DEVEK crank.....
If you are thinking of buying a DEVEK crank, give a call or email me privately....next order is going in soon.
Marc
DEVEK
Marc
DEVEK
John that was a home built customer assembled engine with custom rods .....I did not ask the RPM only heard the power numbers from Mark who talked with the customer .
