84 euro wireing help
Need the help of fellow 84 euro owners out there.
I have 2 hanging wires at plug Z (black 6 pin )at the fuse panel.
A blue one and a red one. one goes to pin 6 the other to pin 4 as these are the only empty ones on the plug. Question is wich?? If you could check this on your car or just plain are a God and know this of the top of your head I would so love you for the info.
Thanks!!
Thurston. 84 euro <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Thanks!!
Rennlist Site Sponsor
The 1984 wiring diagrams in the FWM are virtually useless - they don't even show wire colors!
But:
From page 97-211,
The wire from Z4 runs to terminal 87a on the alarm control unit.
The wire from Z6 runs to terminal 15 on the alarm control unit.
From page 97-153 (1982 Alarm System)
The wire from Z4 to K1(same terminal as 87a on the '84) is brown/white.
The wire from Z6 to 61 is blue.
The only red wire runs from Z3 to terminal 30 on the alarm control unit.
Z1 - blue (engine run signal from alternator)
Z2 - brown (ground)
Z3 - red (battery)
Z4 - brown/white (switched ground)
Z5 - black/white (interior light signal)
Z6 - blue (engine run signal? from alternator charge light)
With the red wire disconnected, the alarm should be disabled.
But:
From page 97-211,
Z2 - brown (ground)
Z3 - red (battery)
