How do i change auto box fluid?
I am going to change the auto gearbox fluid in my euro s2 as it is jumping gear and slipping if anyone has any tips it would be great thanks.
Chronic Tool Dropper
I posted the procedure to Rennlist a while back, and the post is enshrined at the Nichols tip site complete. Look under auto trans and you'll find it I'm sure!
<a href="http://ourworld.compuserve.com/homepages/nichols/tip275.htm" target="_blank">http://ourworld.compuserve.com/homepages/nichols/tip275.htm</a>
That should do the trick for you!
A note: Rich Andrade in Phoenix posted later that he had a problem using the Mobil-1 synthetic ATF that I used in my car and mentioned in the procedure. No way to identify the the Mobil-1 was part of the problem, but the caution is shared just in case.
<img src="graemlins/yltype.gif" border="0" alt="[typing]" />
