CAM cover differences
Cottage Industry Sponsor
Awesome question! I'd like to know more detail on this also - mainly the sunken PORSCHE lettering - is it the same size?
Some 85-86 cars have the cap bolts. I am not sure if they have been converted, but I have one that is that way.
The covers on the S4 have a curve on the corners while the 85-86 covers are squared off.
Dan the Pod Guy
Dan the Pod Guy
85-86 have indents for plug wire boot routing below the spark plug hole. Also, the small screw holes for single plug wire holders are next to, and slightly above, the plug holes, versus the S4, where they are below the plug hole.
928 Engine Re-Re-Rebuild Specialist
The covers themselves have different gaps for different rubber grommets. The 85-86 versions allow the use of rubber o-rings. They fit neatly into the cover as pictured.
The 87+ models use much larger grommets as well as cupped/domed washers that fit over them. The second picture is of the grommet.
