928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine vibration w/new motor mounts
Old 07-15-2007, 03:21 PM
ParkerC
ParkerC's Avatar
Originally Posted by SwayBar
This is good advice; I've read plenty of times where after adding the injector cleaner, the rough-running cleared up. The best way of doing it though is to add the cleaner, run the engine enough for the cleaner to permeate the entire fuel system, and then let the car set for several days to allow cleaner to soak the injectors and do it's job.
Will pick up some Techron ASAP, and follow your advice...If its as easy as this the beers are on me
When for a spirited drive this morning, and it is really alot smoother, less buzz than I than I remember before, esp when punching it
The shake seems to be coming more from the rear,more than anywhere else., but I wouldn't bet any money on it. I can feel it in the back part of the seat more than anywhere else, but that probably where any vibration throughout the whole car would be felt...
Thanks Again
Parker
Quick Reply: Engine vibration w/new motor mounts
