928 Forum 1978-1995
Sponsored by: 928 Specialists
Replacing panel clips?
Old Jul 13, 2007 | 05:48 PM
Aatos's Avatar
Aatos
Question Replacing panel clips?
This is probably a dumb question, but how do I remove the plastic white clips from the door panels?
I have few bent ones and new parts in hand, but I'm afraid of damaging the panel itself by using brute force.
Old Jul 13, 2007 | 07:30 PM
Randy V's Avatar
Randy V
25 Year Member
They 'screw' in.
Hard to describe, but relatively easy to do.
Place the 'notch' of the clip into the panel hole, then turn the clip clockwise.
To remove them I usually just use needlenose pliers and crush the base and wiggle them out. They usually are destroyed when removing them.
Old Jul 13, 2007 | 07:32 PM
RyanPerrella's Avatar
RyanPerrella
I bought some new clips but they are a real pain in the *** to remove. Easier to install new ones but the old ones were a royal pain.
Old Jul 14, 2007 | 03:50 AM
Charley B's Avatar
Charley B
Always plan on the old clips not being reusable and have new ones on hand.
Old Jul 14, 2007 | 10:32 AM
Alan's Avatar
Alan
Electron Wrangler
As Randy says - don't even try to get them out whole - either leave them in if good or snap the lips off the back all the way around so they just fall out. Either needle nose pliers or electrical wire cutters (small) make quick work of them... Buy a big bag of clips and replace them all over time as neeed...
If you try to unscrew they break - but also damage the panel - not worth it
If the panel is on the car & wont come off easily - use an upholstry tool to ensure you are levering at the clip only & not the panel around it or cut/snap the clips off at the front first with a narrow sharp blade (small Xacto - or better yet a real scalpel).
Alan
Old Jul 14, 2007 | 08:03 PM
Aatos's Avatar
Aatos
Thanks for the tips, clips have now been replaced .
