sparkless
Originally Posted by mj1pate
.... I will also replace the crank position sensor (having been through intermittent hell with an aging unit in the past). ....
Glenn
Originally Posted by sharkmeister85
Based on my recent experience, do not replace this sensor unless you have diagnosed that it is definitely not functioning correctly. Although only secured by a single screw to the block, it may be held in the block itself by years of oil, dirt and crud. If that's the case there's nothing to grip or pry on except for the old, brittle electrical connector visible on top. When it breaks off (as mine did), you may find the only practical way to get it out is to drop the clutch and remove the flywheel (as I did), and drift it down and out into the bell housing. A real PITA, but I had a few WYIT's that needed doing anyhow (though I had hoped to do them somewhere in the future).
Glenn
Glenn
Is it not possible to extract it by drilling through and pulling upwards...with something?
....Is it not possible to extract it by drilling through and pulling upwards...with something?
Glenn
