How Fast? (eBay 928 - RV)
Gosh Mr. Goodspeed (if that is your real name
.... You're not putting much credence into the fine heritage of this magnificent automobile...... And you probably didn't even factor-in that you could fit 3 hot chicks in it.......
Hee, hee, hee,....
Best,
Best,
it's sad to think that some of the scammers are off onto the 928 page of e-bay. I've seen a couple that look kinda suspicious.....they are rampant on the harley page's .....2year old fatboys for 7,800 NR, ship world wide.....
It may be a sleeper deal, but I would have a local representative pre inspect the car.....
jt
89 928 S4 Turbo
jt
89 928 S4 Turbo
Originally Posted by Xlot
Bah its gone.. so I never got a chance to read the automotive hilarity ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
From all the quotes, sounded a lot like a well known scam.
Great job Rennlist! Now we just need to keep our eyes open for brucewillis217
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Instead of using BOSCH spark wires with a rubber core he had the special wires built
" Gosh Mr. Goodspeed (if that is your real name.... You're not putting much credence into the fine heritage of this magnificent automobile...... And you probably didn't even factor-in that you could fit 3 hot chicks in it....... Hee, hee, hee,.... "
4 HOT Chicks - one in the back!
And yes, my name is Goodspeed
1 Post
Here is a copy of the text in casse it disappears again!! :
Vehicle Description
Eccentric Rocker’s Estate: This rocker has “gone European” and some his American toys are available for the right offer. This beautiful Porsche has an amazine pedigree! The Porsche was originally purchased for the mistress of a very famous actor–producer but the affair was short lived and the car was retrieved and enjoyed its film debut and went on to make appearances on Simon and Simon, The A Team, The Commish, Hunter, Wiseguy, 21 Jump Street, Silk Stalkings and The Greatest American Hero. This seductive, wine–colored Porsche 928–S is not only beautiful but it is one of a limited edition made by Porsche. It has the original Ruby Red Metallic paint, the paint code is Y–74799. It is an automatic, not a stick, but still drives like a race car. It goes from 0 to 60 in 5.8 seconds. It is not some kind of weekend luxury vehicle. It’s also a long distance touring car and it functions as a racing car. It includes a $1,600 option: an electric passenger’s seat. And of course the 928–S has two back seats – in case you happen to have three girlfriends who don’t mind sharing you with each other on the open road. This baby has a lot of torque and easily drives at speeds up to 157 miles an hour but the previous driver wanted to baby this beauty and also avoid a James Dean ending to his career. so he did all of his speeding only on the race track. In low–profile competition the 928–S has been clocked and verified at over 195 on a great race track with a top driver hired in. This baby has never run hot and locked up. It has been a trouble–free car. The fuel injectors have been cleaned with the Lubro Moly injector pressure system and it has new injector seals. The power steering hoses were all converted with new rubber and metal lines. The trans is in the rear for better weight balance and the trans was power flushed with a new filter and sump gasket. When it was service it swapped out both timing belts and added two new tensioners, a new water pump and all new rubber hoses. The front sway bar busings are outfitted with the Westminster, larger sway bar, with Hemi Rod Ends. The car has a KNN Air Cleaner. This fabulous, sexy, road–runner has been treated like the jewel that it truly is. The oil has been changed every 3,000 miles. It uses Mobile One 15/50. The sump holds about 8 quarts. The tires are Kuma Tires costing $145.00 for each one. The upper and lower, aluminum, control arms (ball joints) and the front and rear rotors were updated with slotted/vented rotors. The brake pads are Porterfields and to raise the car a Devic Carrera Kit was installed. This 938–S has additional amenities.The S means it boasts better tail–lights and also headlight squirters and cleaners. This baby still has the original tire pump in the back and all the factory tools are still in the tool kit. Because he wanted more power out of the engine, both the intake and exhaust were modified for extra horse. Then he had the fuel injectors taken out and balanced and he removed the intake runners and had all 8 of them "Extrude Hone" which provides fluid and air improvement and is worth about 15 extra horse power) He removed the air box and enlarged it with a K&N System worth at least 10 horse power. Then he wanted hotter spark so he had the distributor ship from out of state for "advance recurved" – for better spark. Instead of using BOSCH spark wires with a rubber core he had the special wires built with stainless steel wire which conducts and gives a much hotter spark. He also installed a much hotter coil and used spark plugs with real silver tips. He re–gapped the plugs wider which allowed more advance and added 8 to 15 horse. There are some minor cosmetic flaws. Vehicle pictured is similar in type, shape, and model, but does not have the same paint.
lollololol
Vehicle Description
lollololol
