Leather Dash & Pod Installation (with pics)
Originally Posted by Charley B
Hawk, do you know if the belt was retensioned after replacement?
Original job was thorough, done by Dan at Exotic Motorwerks in Phoenix. Replaced cam belt idler & idler bearing, resealed tensioner (rebuild and bleed) & installed a new boot at that time as well.
Think the belt has loosened up? I should have the tensioner tool next week - safe to drive until then (no hi-rev shifts)?
Thanks,
Hawkeyes
Anytime your unsure of the status of your timing belt you are taking a sizable risk by running the car. The stakes are just so high. There is nearly always some adjustment needed after replacing a Timing Belt. You might be OK, but the safe thing to do is park it.
Originally Posted by heinrich
Who is the 928 leather shop? The glovebox door ... puffy?
With foam under the leather, it rides on top and has room to shrink a bit. Incidentally this is the process used by the factory on the late model Porsche dashes and other interior panels.
Electron Wrangler
Rob,
I agree I think it looks better too. I always think the non-airbag dashes look loose around the glove box like its drooped or the gap is too big... even on these where it isn't actualy warped from shrinkage.
This looks better IMO...
Good job trying to come up with a solution.
Alan
Alan
Artist Formerly Known As 84totheFloor
Hawkeye:
Rob did almost the identical dash work for me; I've been thrilled with it ever since. Enjoy the new feel and congrats on this important restoration step.
VERY NICE!!!
Yank the steering wheel and have him do the same color leather...looks like an afterthought now and would lok sensational with the same treatment.
That looks fantastic and it is the same color that I need done.
Get with some fellow R-listers, the tension check will take just 20-30 minutes and is something you should get done right away.
I didn't try to match every piece as the door panels, roof pillars, rear quarters, console, etc. are still the original leather and a tad darker shade at that. The dash is sooo much nicer to look at without a 'fur' cover or large cracks down the middle.
The black steering wheel picks up the floor mats color as well as other assorted black plastic pieces in the cabin & the existing leather covering feels fantastic.
I'll probably just leave it as is, even though a recover might be more esthetically pleasing.
Thanks to everyone for your comments and suggestions!
Hawk
Congrats bro... looks awesome. I had Robert Budd do my entire interior and Paul Champagne did the steering wheel. They are both fantastic craftsmen. I had the whole interior (including new carpeting) installed by Dan at Exotic Motorwerks and it made a hell of a difference in the car i tell you.
