for those with uh... wider than normal posterior
Louie's flares are 3", so you can comfortably use up to 13" wide hoops without haivng to get out the slide rule. You need to consider the rin diameter though.
In actuality, your question is too vague and can bring many answers that will only bring more questions from you.
What are you trying to accomplish that your car cannot do right now?...considering you need so much more "grip".
Originally Posted by Jim R.
18"x11" with 295/30/18's fit nicely in the stock rear '89 GT quarters. Matching 18"x9.5" with 255/35/18's up front with no problems. These are custom offset Fikse FM-10's, but I don't know the offset specs off the top of my head.
The real question needs to be how much wider than that will GTS quarters allow, and will it actually help with traction if SC'd. Even with 295's I have traction issues with the GT gears and 5spd. With an automatic S4, you might be fine.
Jim
Jim
I don't mind asking more questions (and I appreciate every answer I get). I am planning to supercharge and then re-paint the car. I like the look the wider rear fenders provide and am considering installing the flares when doing all the other bodywork. Before I do that, I would like to weigh the pro and cons both in terms of handling and in terms of availability/$$. So, this has relatively little to do with the car's current capabilities. Your sarcasm is duly noted though. Thank you.
