A-pillar removal
I am trying to remove the A-Pillar vinyl covering and can’t seem to figure it out. I have removed the one screw that connects at the top, but I don’t see any screws at the bottom where it sits against the windshield. If anyone has any info on how to remove this please inform me. Thanks so much
Quinn.
PS If we all go in on the F.A.S.T Supercharger kit you think they’ll give us a group rate?
<img src="graemlins/yltype.gif" border="0" alt="[typing]" />
Quinn.
I did this on the drivers side a couple of years ago to install a mirrow with direction and outside temp in it.
There is one screw at the top and the rest is made of metal plates that slide into the fittings in the windshield hold down. Much black goop in there also. Must tap out from door towards the window... easyly.
Good luck.
Bill
Good luck.
Bill
Cottage Industry Sponsor
Hi Quinn:
There IS only one screw, then the cover clamps to the A pillar. Once you get the screw out, you just have to pull the cover off at the top, then lift it out from the corner of the dahs board.
It has to be tight - otherwise it would rattle...
