Knock sensor connector info??
Team Owner
Does anyone know where to get new connector(female ) pins for the knock sensor connector on a 88 S4, I removed the 3 old pins and they are destroyed the plastic connector housing is still good, I just need the parts that slide onto the knock sensor (male pins). thanks, I hope someone knows where to find these , my wires had started to shed their insulation and i was working on fitting heatshrink to the wires but the pins wouldnt come out of the connector of the car harness and thus are now destroyed. Thanks Stan
Inventor
It's the same terminal as used in the ECU connectors.
Wurth/Würth #05589969 - VW Elect Conn Non-Ins GA14-16
Team Owner
Thanks for the kind replies, I ordered anew connector with boot, Stan
