BEGI owners
Thought I'd pass this along to fellow BEGI owners. I'll post on the Twin Screw thread as well...
Bill (koenig928) and I were finishing a Shark Tuner session when I noticed my fuel pressure gauge was pegged at 99 psi at idle! I immediately turned off the engine; luckily we were at a turn off an no traffic. I popped the hood and didn't see any problems, and then we checked the fuel pump fuse and relay, both good. I started the engine and had normal pressure. We logged another WOT run and went back to Bills to burn an EPROM.
She ran fine for the first 8 miles then the fuel pressure pegged at idle again, I'm assuming it was in the 100's because my gauge only reads to 99. Only this time I was in a bad location on one of our busy highways and no shoulder to pull off on. I couldn't start the engine because the pressure stayed maxed. I started checking the basics as before and the then removed the fuel pump relay and jumpered the connections, still pegged 99 psi. Then I tried to by-pass the BEGI by removing and capping the vacuum lines, it still didn't change the fp. Had to call a flatbed to carry her home
As soon as we got her parked in the garage, I checked one last time and it was still bad. So I decided to go after the easiest thing first, I took the BEGI apart and sure as **** the aluminum square was cracked which allowed a constant vacuum leak? Luckily I had several spares on hand that Mr. Corky Bell himself sent me several months back during trouble-shooting inconsistent fp's. I replaced the aluminum, put it back together, and she fired right up
I can't believe how the BEGI is put together; in theory it's a big component for such an easy design. I'll be very happy to get rid of it and not have to worry if it's actually regulating my fp's correctly
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Originally Posted by BrianG
Anyone want a BEGI?? I have a spare!
Free?
http://search.ebay.com/search/search...egi&category0=
It's an after market Fuel Pressure Regulator designed to operate off vacuum.
Here's a pic Tony took a while back. It's the one that looks like a Flying Saucer![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Originally Posted by Randy V
OK, I'll ask - What's a BEGI?
Inventor
Do you still need all those gadgets after ST'ing?
