headlight motor repair
#31
Electron Wrangler
But in the S2 system the motor only rotates in one direction, so headlight transition from down to up is the same motor movement as for up to down.
So as long as you have the headlights physically in their correct position, should it not then matter for the S2 which is which?
Not trying to be difficult, but as I have a relay unit that I'm not sure is working 100% correctly I can't verify for myself.
Alan
#32
Something is obviously cactus with my setup as the headlights come on as soon as I move the light switch to position 2, regardless of whether they're physically up or down.
Thanks,
Brian
#33
Electron Wrangler
