(In)famous Y fitting
Basic Sponsor
It is a plastic Y fitting at the charcoal canister under the passenger front fender.
The Y cracks and leaks gas fumes which are normally collected in the charcoal canister.
Replace with a stainless steel Y connector.
I sell them for $21 as well as do other sponsors.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Archive Gatekeeper
Roger-
Do you (or anyone else) ever bother to change the charcoal canister? It can't be terribly effective after 15-20 years, though maybe the broken Y shields the canister's charcoal from getting saturated/used up.
They're only $40 or so. I wonder whether a new one would make any real difference in a car with borderline emissions. Probably not, or we'd hear more about chagning them.....
Basic Sponsor
Rob,
We changed one on Doc Mirrors 90 GT and did not see any change.
Apart from that and changing plenty of Y pipes no other info to add.
Roger
Roger
Originally Posted by Giovanni
Is it essential to have a y fitting or a t fitting will do the job? Sorry for the stupid question.
It may work, but I think it's a space/routing issue with the tubing, which isn't amazingly flexible.
This part breaks on many 928s and causes gas fume smells. I bought the very well made stainless steel "Y" from Nicole and will never have this problem again.
Harvey
Harvey
it has to be a Y fitting in Porsche Font
T will do the job as long as you have the room i imagine.
Chronic Tool Dropper
Use the Porsche plastic of the Roger SS Y-fiiting. Don't waste time building a T out of sprinkler parts that will melt from the gas fumes.
Rob-- The activated charcoal is a lifetime thing. It soaks up vapors when the car is sitting, then the engine sucks those vapors into the intake and enhances combustion when running. Only reason to replace is if the cannister gets broken in an accident or during y-connector surgery.
Karen--
Look at the attached PDF for a simple step-by-step replacement instruction. I took the pix with a $800 digital camera back when 640x480 was hi-resolution. The words don't grow old, however.
Karen--
