uhh 85 928S Radiator had oil, trans fluid, and coolant.
Took out the 85 928 Radiator out of my dad's car and it appears, trans fluid, oil, and coolant is all coming out of it. They are not mixed together at all every line we disconnect had a different fluid coming out of it. Is this normal? I'm confused all though im not much of a 928 mechanic..
Your radiator has (in the end tanks ) trans cooler and oil cooler. As long as the fluids are not mixing by themselves, you are fine.
