Is an Intake job in my future?
Captain Obvious
Super User
Super User
[QUOTE=Shane]What kind of oil are you using?
Not the end of the world, but it is an engine removal job to pull the heads, since the '85-'86 use studs instead of bolts.[/QUOTE
I pulled my heads with the engine in th ecar ('85 32V).
Captain Obvious
Super User
Super User
Originally Posted by Hacker-Pschorr
Valve guides & seals are a wear item - don't feel bad. My mechanic has seen 944 / 928's with worn valve guides in as little as 50,000 miles.
This might make you feel better. The Ferrari 355 my father is looking at has an issue wearing out valve guides prematurely. A valve guide job on these start at $7,000. So be happy you don't have a 355 Ferrari
Compared to the 355, the 928 will cost little, but at $3000+ (inluding labour) it is a significant amount.
