Front radiator flaps
Hello,
I've always been curious as to why 928's have those flaps/doors in front of the radiator that open and close by a little electric motor. What is the purpose of blocking air to the rad? Doesn't a 928 have a regular thermostat to insure proper warm up????
Thanks,
Tom
Thanks,
Tom
I believe Porsche added them to get better drag co-efficient numbers in the WIND TUNNEL (closed position) for marketing purposes. However, the flaps would probably be open at high speeds on the open road...hehe..
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Are those the infamous cooling flaps that can be disabled by removing fuse 23 when the engine is off ?
Has anyone done this ? It almost seems too easy... just to get a little more cooling.
"Are those the infamous cooling flaps that can be disabled by removing fuse 23 when the engine is off ? Has anyone done this ? It almost seems too easy... just to get a little more cooling."
Different years used different fuses. I find it is much easier to disconnect the power cable to the flap motor once they are fully open. ;^)
Also, for those of us that drive during the winter, they help in getting the engine warmed up a bit sooner. :^)
~ Merry motoring ~
~ Merry motoring ~
