Button?
We had a choice?
Damn it John,
Don't we have enough problems to try and figure out about things that actually wrong with our 928's? Now I won't sleep at night trying to figure out what it is. I've been through the shop manuals/owners manuals to no avail. I think I might know where your thoughts are headed though. The wires on my reservoir attach to the side of it, could it be the answer to your current brake warning light woes? I hope someone enlightens us before I go to bed. My dreams tonight are of fixing the low voltmeter readings.
Anthony Tate
79/928 Silver Metallic <img src="confused.gif" border="0">
Anthony Tate
We had a choice?
With all the infinate wisdom and the plethora of superfluous BS on this site, no one knows what it is?
Anthony Tate
Cranky from lack of sleep <img src="graemlins/crying.gif" border="0" alt="[crying]" /> <img src="graemlins/sleep.gif" border="0" alt="[sleep]" />
Anthony Tate
John,
The button is part of your low fluid level switch. Not sure why it has the rubber top unless it is set up to press and check your warning light. Tried pushing it on my silver 78 but nothing happened (no light). Can't check it on the black 78 since the battery is out of it (along with the front of the motor-another story).
Dennis
Dennis
Supercharged
If it's anything like the fluid resevoir on my 66 E-Type (and it probably isn't), it's a space for the float rod to travel up and down. See, on the E-type, there's a rod with a cork (preferably champagne!) on it. When the fluid goes down, the cork goes down and eventually pulls the rod down too. This causes a circuit to be made and turns on the dummy light. Pushing it down may not be enough to trigger this. Just a guess.
Andrew Olson
82 928 5 speed
Andrew Olson
82 928 5 speed
Registered User
john, just curious, is the word "IRAQ" located next to this button? if so, you really are an ASSET to your country. press it and then check CNN.
<img src="graemlins/icon107.gif" border="0" alt="[icon107]" />
User
Dennis and Andrew,
Thanks this 'seems' the most likely.
Dennis,
Thanks for that site, I'll check tonight!
Snow,
Are you sure you aren't connected to:
GREEN SPRITE ?
You have just found another piece of my convolted history. Just a piece though...
My wife and I spent a chunk of our lives at the Indian Head Naval Ordanance Station, after a serious 3 weeks at Redstone Arsenal -huntville,ALA- playing with 'live chemicals'.
You won't be hearing posthumous commentary about me on CNN, but to be truthful I do 'sweeps' occasionally on everything including Pattycakes...you never know. Also use an old rotary phone, because I do know!
John S. and Pattycakes
<img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" /> <img src="graemlins/icon107.gif" border="0" alt="[icon107]" />
Dennis,
Snow,
GREEN SPRITE ?
