How to reach the tensioner?
Well I'm plodding along with retensioning the belt. Cambelt cover now off, got cold feet about taking off the fan shroud when I looked at the oil cooler line nuts and anticipated a frustrating time trying to undo them/buying correct wrenches/trying to fit them in with shroud pushed back. I found I could get good access and turn the crank ok from underneath (wife will help call TDC!), but I will remove plugs to make it easier.
There was a funny moment when I pulled out the dipstick tube with almost no effort at all, and had an anxious few minutes reassuring myself I could get it back in the sump!
But looking at the tensioner access to the tightening nut and the locknut is pretty tricky (it's a 928, stupid). There's a maze of belts in front of the tensioner (presumably these aren't there when you install a new TB) so it's going to be hard threading a wrench through to the tensioner. It also looks as if you can only do this from underneath. In fact I can only just see the tensioner nut from one particular angle underneath the car since it's blocked by AC compressor.
I had got an oil can ready and oil for re-filling the tensioner, but that looks hopeless given the lack of access.
So any tips please for getting at the tensioner?
I usually drop the belly pan to spin the crank from below - can be done single handed if you have a small mirror to see the marker - and the plugs can stay in, for one has good leverage from below.
Additionally, I prefer to drain enough from the rad to remove both the top and fill ( ~1") hoses: aside from easing removal of the dist. cap, there is now better access to the 17mm lock nut ( shorty spanner req'd) and 17mm adjuster.
If you have the air pump, toss it and access is improved greatly.
Were you to just add oil to the tensioner, a hose on a squirt can and a 7mm wrench for the bleeders will take the better part of 10 min.
If I remember, when we did mine, Capt. Earl had a wrench that he had basically shortened for easier access. I also remember he ground it down to make the jaw end thinner so I could access the adjusting nut easier without getting interference from the locking nut.
Hope that makes sense, but the short of it is that the shorty wrench was the ticket.
