brake line replacement
I'm covering additional 12hr. shifts in the ER and have limited time and need to prioritize things before SITM. I was going to replace the brakes lines on my 88 S4, and bleed and use Blue.I have the lines, but does the banjo bolts have washers and can they be reused or do I need new ones. If I need new ones I'll just bleed the system and replace them after SITM. This way I can plan what I'll do tonite. See you at SITM.Ed M
