Turn sognal and Hazard lights inop
'86.5 Symptoms:
Car running turn signals and hazard lights inop. Green signal does not blink.
Pulled relay V. Not juice to the relay. Tried a spare relay from my '85, ng.
With all the messing around I did with the pod I am sure I blew a fuse. But, I cannot tell from the fuse chart which one.
With the car off the turn signal will turn the parking light and driving lights on. Ignition on, no lights at the four corners.
What gives?
What gives?
No expert but :
A.) you crossed some wires while in the pod.
OR
B.) Could be that bulb/lamp control switch Tony and I have been doing battle with.
If it's 'B' there should be some caution or warning lights on in addition to the Master caution saying HELLO.
Only other thing I can think of is when you pulled the Pod you also pulled the steering wheel and the turnsignal/cruise rig, too. Right? Therein may be where your problem lies.
OR
Turns out I fried the hazard switch yesterday. My bad. I did not disconnect the battery ground before I pulled the pod. Ooops.
Oh my,
How in the world did the Hazards tie into the driving lights...don't answer...rhetorical question.
MUST GET MANUALS
Thanks for the update ...just when I thought all possible spark glitches had seen the light of day,
a friggin new one.
Even though you messed up by not disconnecting the Batt. it's always refreshing to find yet another possible combination of light problems.
thanks for the info...I think.
John S & Pattycakes <img src="graemlins/drink.gif" border="0" alt="[cherrsagai]" />
MUST GET MANUALS
a friggin new one.
