Cruse Control wires not connected under wheel well !
Located in the Vacuum ***** for the cruse control under the drivers wheel well
I have 2 wires, brown and Black with White stripe both with small female spade connectors not connected. Before I start taking things apart are these not used or has PO disconnected them for a reason. If they are removed where do they go not much room to see and I assume they were removed for a reason, yes the cruse does not work!
Electron Wrangler
They are probably the wires the the Euro/ROW side turn signals you don't have. The looms are common - so on US models they just dangle there...
Alan
Alan
This was the thread for when I asked the same thing:
https://rennlist.com/forums/showthre...ghlight=cruise
I removed the round canister not the *****, I found the other end connected to the bottom of it. The wires seem to go noware I canot believe this is a Euro connection or am I wrong.
Administrator - "Tyson"
I recently took apart the same spot on my car - found the same wires.
Electron Wrangler
Black with a White stripe is the correct color code for a rear/side turn signal wire on the Left side of the car, Brown (Ground) is the appropriate wire to pair with this for a turn signal bulb... So I'm pretty sure thats what is it (and it is not supposed to be connected on your car).
Alan
Alan
The round canister with a vacuum line on the top? It's for the cruise control.
Well that settles that; No one knows what that round cansiter does wonder why its there! I'm going to put my liner back on and not worry about it!
The round canister is the cruise vacuum actuator - that's what actually holds the throttle position when you turn on the cruise. If it's not working, it could be a vacuum issue, but most likely the cruise amp is not working. Dave (sharkskin) has a great write-up on the CC:
http://members.rennlist.com/sharkski...ugeGremlin.htm
It sounds like yours may actually not be connected right. Can you take any shots of under there to give us a better idea what specifcally you are referring to?
