928 Forum 1978-1995
Sponsored by: 928 Specialists
vacuum question
Old Jul 10, 2002 | 01:24 PM
iantdopps's Avatar
iantdopps
Post vacuum question
I have an 82. I am missing a valve in my vacuum system, and do not know if it was done intentionally or not. It is the valve that is at the rear of the engine, under the airbox and behind the throttle body, sort of to the passenger side. I believe it is a part of the A/C system. It screws into the engine and has 2 horns that come off it. One say "carb" on it and goes to the throttle body. Anyone know what this is for, and the advantage/disadvantage of having it disconnected?
Old Jul 10, 2002 | 04:04 PM
Curt's Avatar
Curt
From: Ventura California, where the girls are so fine.
Post
iantdopps, it sounds like you might be refering to part of the smog pump equipement. It also could be part of your egr system. I will have to look at my car to see if its setup the same as yours.
Old Jul 10, 2002 | 04:25 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Post
Check under your hood and see if you can find the vacuum diagram that was normally installed there.
That would give you a better idea of what the valve did - or at least more info to use when you ask about it.
Old Jul 10, 2002 | 04:35 PM
Jake928's Avatar
Jake928
8th Gear
Post
Sounds like the thermo valve. It's a little brass looking valve with a black plastic top and 2 ports going into it. The whole assembly screws into the engine on the passenger side. Mine was bad and was making my engine run rich. I replaced it for like 30 dollars and everything is OK now. Hope this helps.
