"Clack Clack" sound from behind dash vents
I'm getting a loud and distinct clacking sound from the center vent area of my dash. It is intermittant, but lasts several seconds when it starts. Has anyone experienced this? How hard is it to get in there and see what's wrong. Any tips or links are much appreciated. Thanks.
Steve
'89 S4 Auto
Steve
'89 S4 Auto
Thanks Heinrich, now what do I do about it. Is this a symptom of a bad actuator diagphram, or is something just loose. I'm tempted to just plug the vacuum to the comb flap rather than tear into the dash. My dash is perfect and I'd like to keep it that way. Thanks.
Steve
Steve
Check out Greg Nichol's tips for replacing it. Luckily '89 was the last year before passengerside airbags so you just have to remove the center console, glovebox to perform the surgury requireed to replace it. You can get the rubber actuators from one of the Rennlist Sponsors.
H hit is 100% right.....since it really doesn't do much I also vote to cap the line and forget it....thats what I did.....just so you know the "failure" mode of the comb flap is in the down position....which diverts airflow from the center vent to the side vents......which I like better anyway....about the only downside is it does add a touch of wind noise on higher fan settings
A clacking comb flap can be caused by a faulty check valve in the vacuum line coming off the brake booster. It's a little blue and black thing about an inch in diameter and it costs peanuts to replace. 928 Intl stock them. Worth a try before you climb into the dash. In my RHD car there is a hole in the duct through which the position of the comb flap can be felt with a finger. It doesn't bite too much.
Colin. 89GT
Colin. 89GT
Colin. 89GT
Colin. 89GT
Steve
'89 S4 Auto
Steve
'89 S4 Auto
Give 'er a try!
Todd
