Motor swap in an 81' US
I'm thinking about purchasing a backup motor to build up for my 81' US. I have the stock 4.5 now, but was curious what motors I should look for and what is the easiest swap. I imagine the 4.7 is pretty straight forward. How new can I go? S4 would be sweet!
The amount of money I've spent replacing parts and the head gaskets I probably could have bought a motor and dropped it in already!
Administrator - "Tyson"
Look for a 4.7 liter vs. a 4.5. Everything is a direct swap (heads, intake, oil pan etc...) Except the 4.7 is cheaper to rebuild.
Piston rings for a 4.5 at 928 Intl are $135 per piston. 4.7 liter is $33 per piston.
When I found out the piston ring cost difference I picked up two 4.7 engines
One for each OB
One for each OB
Originally Posted by 928fan4life
Is the 4.7 a non-interference engine as well?
AFAIK they are also non-interference.
If you slap Euro heads / cams on an 83-84 that might be a valve bender.
If Anderson suddenly gets a run on 83-84 motors, I should get a cut
Originally Posted by chewy8000
What about dropping a 32V motor in? Possible? Anyone done it?
The electronics are very different so the swap is very complex compared to a 4.7 into a 4.5 car.
Euro heads can make a diference correct?
Best N/A 16V engine combo using all OEM parts:
85/86 lower end with 84-85 EuroS upper end. I've seen quotes between 270-300 rear wheel horsepower. Lean-Louis was making 270ish rear wheel with a 4.7 lower end with Euro S upper & CIS.
Any other combination will be less
IMO keep it stock (lower compression) and boost the snot out of it.
